Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Saw was running great ,then just stopped and would not start again
Posted by two3 on
Jeff Bonvallet
    Scholar:
  • 41 Answers
Always keep in mind that you need 4 things to make combustion happen: Fuel, Spark, Oxygen (Air), and compression. One or more of these is missing and we need to figure out who is missing the party.
Let’s start with the basics:
Does it have gas? (Fuel)
Is the kill switch on? (Spark)
When you pull the cord slow does it give intermittent firm resistance? (Compression)
Is the air filter clean (Air)
Now you need to look at a few details:
Pull the spark plug out and checked for spark. This requires you to hook the spark plug up and let the plug lean up against the metal part of the head. Pull the cord, should be easy (no compression) and check for spark. Don’t hold plug with fingers as you may get a jolt. If no spark, try a new plug, still no spark check the switch and wiggle it around. Even if you have spark I like to install a new spark plug for this next test. With new plug in, pull at least 10 times, pull the plug and see if it looks wet. If it is wet, it is getting fuel.
Hope this helps.
Posted on Apr 02, 2010
  • John Moore
    John Moore Aug 08, 2014
    If I have a spark and I'm getting fuel into the cylinder, and I have compression, and the air filter is clean, what the heck is making it not even cough?
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
Chainsaw stops running
When it starts to die slacken off the fuel cap enough to allow air into the tank, if it picks up again it is an issue with the fuel tank breather, if the breather is blocked it will create a vacume in the tank and stop fuel flow to the carb.
Apr 24, 2012 | Husqvarna Garden
Poulan PP4218AV 18" Chain Saw
Sounds loike its running lean, start by replacing the fuel filter on the end of the pipe in the fuel tank, if this does not help you need to richen up the mixture screws, unfortunayly you need a special toll to adjust the screws ( they have a spline, not a screwdriver slot ) the tool is part no. 530035560, once you have the tool unscrew the carb screws 1/2 turn on each and try again.
Feb 13, 2011 | Poulan PP4218AV 18" Chain Saw
My 25-year old Craftsman radial arm saw was stored and not used in a damp shed for many years. I got around to completely refurbishing it, tuning it up, and making a great work bench for it only to find...
start with the capacitors. you may have 2, a start and a run capacitor. also you can spray the inside of the motor with WD-40 and turn it by hand until it feels loose.
i was just looking through old post and saw yours.
Dec 11, 2010 | Craftsman Saws
Do I have to use ethanol free gasoline?
It had better do so--or any saw brand that fails to run on ethanol blended fuels will see sales fall rapidly in the USA. We, personally, own one of these same saws which (when new) ran great for about 3 days, then refused to start. A trip to the warranty repair station got us a new ignition module. After return, it ran for about two days, then would not start again. The warranty repair then installed a replacement carburetor and about a year later, still seems to be working fine--it's a great hard working saw when it operates correctly. Good luck!
Jul 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
John deere chain saw CS 56 idle adjustment
check the choke lever rod possable loose or off
Feb 11, 2010 | Poulan Pro Chain Saw 46cc 20"
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
357 people viewed this question
Top Poulan Garden Experts
dannydoesita
Marvin
Marvin
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
