Garmin nuvi 205W GPS Receiver Logo
Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
First time using my garmin 205W and it only holds satelite service for about 10 minutes
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Apr 04, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882213
Points
4663
I recommend you replace the firmware and system software using webupdate. Updates in the Nuvi 205 firmware has increased its satellite reception and accuracy.
I hope that helps.
My garmen Nuvi GPS takes a while to find the satelite when first plugged in
Try to connect it to your computer and update the satellites positions.
tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
How to Perform a Hard Reset of your Garmin Nuvi 205W
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
I hope that helps.
1helpful
It starts but wont let me push agree to start maps
Try resetting your 205w some earlier versions have a reset button on the bottom, if not turn off the unit then turn on but hold it in the on position for about 10 seconds till it restarts.
Thanks for using FixYa
1helpful
We have a Garmin Nuvi 205W GPS. Was plugged into car outlet when it went to a black dot display. Nothing happened when blk dot was pressed. Now we can't get it to turn on at all.
Have you tried resetting the 205W. There is a reset button on the bottom of some of the units if not power off the unit and then hold the power button for about 10 seconds till it starts, it should go through a start up and then reboot itself. See page 42 of manual. I will attach a link to the manual, click here.
1helpful
Location of rest button on garmin nuvi 205w
Some 205W have on on the bottom and some you just need to power off the unit then hold the power button for about 10 seconds until it reboots; see page 42 of owners manual (see link below).
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
Jul 23, 2011 • GPS
My garmin gps takes ages to find the satelites - up to 3 hours, even under clear skies with no overcast
Try hard resetting which will require you to press a small button on the back or bottom of the device with a paper clip. Hold it down for five to ten seconds. Try and see how long it takes GPS to acquire satellite reception. You can also try the customer service number US Toll Free: 1-800-800-1020 to inquire further.
We have two identical nuvi 205w units. While in
Replace the battery 9 times out of 10 the battery ran out of its cycles replacing this will hsore up a varity of errors. I hope this info helps please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
GPS problems wit a Garmin Forerunner 405
The instructions say touch and hold GPS and to go outside away from tall buildings and to remain stationary for several minutes. Not really sure what their definition of several minutes is guess thats their way of saying "sit still for as long as it takes." If that doesnt work I would get in touch with Garmin. 1-800-800-1020
16helpful
5answers
Garmin gps 45xl
To bring your Garmin 45 XL back to life ( reset ) hold down page and start untill the screen comes on. It will take up to twenty minutes to locate your available satelites..
Good luck
Vic
Mar 20, 2008 • GPS
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
