Hello :
You should sniff the motor first . If there's a bad smell , then the motor is burned . You If you can fix it by yourself , then dissemble the unit,
remove the motor. Loosen the bolts running from end to end of the motor
and with emery cloth, clean the small metal plates on the ehd of the
armature. They should be bright copper color. If the armature is burnt,
they will be dull brown. The other thing is to replace the brushes in
the motor . Or take it to a repair shop if you are not sure that you
can fix it by yourself .
good luck .
please rate !
wrong answer.
the power jack is dead!, so will be the fan.
read his post 1 more time. ok?
the OP asked if there is REST.
he meant to type RESET with and E.
no, this is not a computer here, at all, sorry
no RESETS.
the jack is dead.
that means the breaker is blow,
or the switch to turn it on is bad.
or loose wiring,(a danger in its own right that)
this fan is super super simple
2 wires and 1 switch and a motor.
if the motor jack is dead (it is)
then the switch is bad
or now power to the switch
or the wiring fell loose
or service panel, breaker tripped.
http://www.fixya.com/support/p128679-bro...
