Question about Citizen BL5314 52E WR200 Eco-Drive scyba watch
How do I manually set my Eco-drive wr200
I can't remember how to set this thing to the correct time
Posted by dlotz13420 on
Arturs Kalnins
  • 2,338 Answers
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please
Posted on Apr 02, 2010
rehanuk1
    New Friend:
How to set time for pakistan
Posted on Nov 01, 2012
How do i set the day (Mon-Sun) on my ax2013 watch?
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
Mar 24, 2011 | Giorgio Armani A|X Armani Exchange Black...
I have a Westclox, Calander Model 70026. I have set the clock several times to the correct time,(with the time zone at the proper setting) but, after a day or so, the hour reading, reverts back...
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Sep 27, 2010 | Watches
Oh, one additional thing about my CASIO 'WAVE CEPTOR' watch: After I got (finally) the manual and set up the watch, it set the DIGITAL display to the correct time & date, but the ANALOG display re-set...
You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
(Check out this with the instructions- it is all there!)
May 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cant set the time.
does it have screw down crown if so you need to unscrew it anti clockwise once you do this you can set time etc if it does have screw down crown remember to scew it back its spring loaded so you need a little pressure if you dont it wont be water resistant..
Mar 26, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
How do you set the day/date on a watch????????
Try this solution I posted earlier for a similar problem.
Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time.
If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Hope this solves your problem.
Jul 17, 2009 | Seiko Wrist 5 SNKA03K1 Automatic...
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
My boss has a Citizen Eco Drive Skyhawk watch . . . how in the world do you set this thing? Every time I try, the second hands goes buck-nutty and spins around the dial a million times, then goes...
good morning ! to set the Eco Drive Skyhawk citizen watch,full the crown carefully wind it slowly until you reach the correct time after that push the crown back to normal possition, if the hand is turning back to the wrong time just press the button on the up side until the turn to the correct time,thank you ! god bless !...
Aug 28, 2008 | Citizen Watches
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
Aug 03, 2008 | Breitling Hercules 246/GRY/PROF
How to set time in the citizen ecodrive skyhawk
http://www.citizenwatch.com/Technical/English/Abbreviated/C650_condensed.pdf
A correction from the last post, you don't need to do All RESET. Read the section right below that. You put the needle on CHR, pull out the dial and set calibrate the hands without resetting the whole thing.
Mar 03, 2008 | Citizen Blue Angels Skyhawk Watch
Setting the day on my watch
If you can tell me what model number and who makes the watch I can help you locate the manual online.
Jan 07, 2008 | Watches
Citizen BL5314 52E WR200 Eco-Drive scyba watch Logo
3,030 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Lisa Christine
Bruce Robin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
