That is called lag. it often happens on Bluetooth, satellite or Internet based television where the internet isn't fast enough for the quality of the broadcast. Often, you can fix this if you have a Pause feature. Pause for 5 minutes.
A small rip or tear in the diaphragm will cause that problem. When you put your hand over the mouth you are creating more suction to the diaphragm. Replace diaphragm.
Does this happen with both Blu-Ray discs as well as DVD-Video?
If so, it may be the connection or your TV.
If it only happens with one or the other, its a problem with etiher the Blu-Ray lens or the DVD lens and i would advise contacting Samsung to arrnage a service.
If its happening with both, try repalcing the cable you are using and test the Blu-Ray on another TV
The video and audio are processed along different paths when they are converted from digital information to analog. Delays can surely differ between them.
If the system doesn't provide any synchronization adjustments on the menu and the unit is out of warranty, you may be stuck with the problem, one that does not seem to be common to your model.
A crappy HDTV (Ilo/Walcrap) we have, will sometimes randomly do this and there are no 'fixes' for the annoying problem.
This is an issue that has been going on for some time with Samsung. This is call Lip sync. To fix this problem you need a software upgrade. If you are under warranty, we will change the signal board.
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
