Terk XM Commander Satellite Radio Receiver Logo
Question about Terk XM Commander Satellite Radio Receiver
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does not change anything. can u help me.
Posted by vincemilitel on
John
  • Terk Expert
  • 509 Answers
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Posted on Aug 10, 2010
No sound when song is playing on my car stereo from ipod and my volume is loud enough to be heard
What kind of radio do you have? whats the model # of the radio? how do you have the ipod connected? Is it thru usb or 3.5mm aux jack? what model ipod do you have?
2answers
PLAYING IPOD THRU SYSTEM
i think you will have to try a new adapter for getting this problem fixed.
please use a new one
My right side speakers have stopped working fully. When I set it to only right side, i have sound, but it is extremely low no matter how loud I turn it up. It also doesn't matter if it is set to just...
Could be worn volume-control (potentiometer), dust/oxidizing on wiper-track of same control.
Buy contact-cleaner spray,such as Servisol, McKenic, Kontakt or similar.
If linear slider-type volume, attach tubular nozzle/guide thingy to spray head, squirt cleaner into slot while zooming back & forth (stereo OFF).
This scrubs the contacted surface while cleaning.
If rotary type, remove stereo, open cover, locate volume control, squirt into control while dialling up and down.
Allow a few minutes to evaporate (quick dry spray is best).
How aux works?
The Aux works when you have the RCA jacks from a DVD player or video game connected to the back of the stereo. When in that mode, the stereo will play the volume from that device.
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
9helpful
Setting the time in my alpine car radio
hold down the sound button until the settings pop up. then keep scrolling until you find clock stg. After you find this, click the play/pause button on the top left of the stereo and the hours will blink. then press it again and the minutes will. you change the number by scrolling with the volume button
2answers
Need to crank the volume to hear XM Radio
Defently take it back to get fixed it shouldn't work that way. it should be the same or louder when your deck is set to 20 for the volume
Car stereo receiver
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there.
If you don't have the manual, find it on the official website.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
The link to download it is on the upper right.
XM 2 GO Not Playing
I had the same problem. I had to reset (use a paper clip into the RESET hole under the battery cover ( or pull out the battery for a a couple of minutes). Then, after recording some songs, I switched over MYXM and then began rotating the channel selector dial. The volume indicator arrow moved off zero and began advancing up the volume scale. I kept doing it until it about half way and my sound was back.
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
