1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
SOURCE: scan multiple pages to one file
Hi Clint...
There are several programs available for downloading that work as print to pdf... some free some not. You can try pdf creator it's free and works well for me, the download isn't very long and the install is super easy.
after you install the program, you should see a pdf printer in your printer selections. You don't want to try to save your file, you have to select print and then select the pdf print to file option in your printer selection. Print the first file to a file you create to save it as a pdf. for the subsequent files you will need to choose Append to an existing pdf file and select the file you have created.
Test the file to see that both of your scans are in there and that they are in the order you want them to be in. If all that works find, you can follow the same procedure with each scanned page and they should all end up in one file.
the pdf print to file is also a great way to save webpages in one single file :)
hope that helps!
bru
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
SOURCE: samsung scx-4200 does not give me the option to scan to pdf file
I used a program called SmarThru 4 with the same printer-scanner. Works. Give it a try :).
