Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
I have exact same problem. Let me know if you find an answer.
No dial tone. I can call out and reach number (though no sound) so connections are there but just no sound.
For incoming calls, phone rings, pick it up, no sound.
Any solutions??
Try a harware reset! dont worry this will not delete anything on your handset. it is a simple procedure:
while the phone is on take out the battery and then the sim
then insert the battery by itself and power it up.
It should ask to insert a sim or something along those line.
when it does take the battery out again while the phone is on.
put it all back together and power the phone up again.
If this does not work.
Try MnuL ROm in network settings. search manualy and select a different network to what you are on and then do the same and go back to your service provider. then reset back to automatic.
if that does not work there is one more thing.
if the handset is 3G try setting to GSM mode only.
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
