Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
How to remove deadlatch on door
The latch won't move to open door. I took off door knobs and removed stuff that opens door but the latch is stuck in latch hole and there is no way to get it to move to open door
Posted by Janice Dodson on
1 Related Answer
chadd
  • 60 Answers
SOURCE: tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Posted on Oct 18, 2009
Open a crew cab stuck door on F-150 pickup truck
check the opposite side door to see if you can take off the inside door panel with the door closed. If you can, remove the door panel and find the cable/mechanism to the latch, move it to open the door and fix/replace.
Sep 27, 2014 | Cars & Trucks
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Door latch stuck on volvo c70
It sounds like the actuators (usually stiff wires) from the door handles and locking knob are OK, which means the latching mechanism itself is probably jammed or broken.
You'll need to remove the upholstered panel covering the inside of the door (search online for "how to remove a door panel") and investigate, pulling on various rods or cables to get the latch to release. You may have to temporarily remove part of a plastic water shield under the door panel to gain access.
If you can get the latch to release, unbolt it from the door (usually from its side), spray every part of the mechanism that you can access with a light lubricant like WD-40, and see if that helps. Try operating the latch manually by pushing with a screwdriver to see what happens. Look for any broken or jammed components or connectors.
If it still doesn't work, but all the related handles and knobs appear to be connected and moving properly, then the latching mechanism itself is probably at fault. Removing it is usually a matter of disconnecting all the control wires or cables, but take notes on how they connect so you can re-assemble everything). New latches are available from the manufacturer, or you can probably find a used one online. These are normally very reliable items, so I wouldn't hesitate to buy a used one.
Apr 11, 2014 | 1999 Volvo C70
Door latch stuck
Bend down on one knee and use one hand to hold the exterior door handle in the open position while using a screw driver to disengage the door latch by inserting the screw driver's tip into the anchor hole and push the screw driver outward towards the car.
Dec 22, 2013 | Cars & Trucks
Nissan pathfinder rear door won't open
I have had this issue twice on my '98 Pathfinder. The hinge inside the exterior door latch rusts over time and sticks. As suggested in some other answers, the BEST way to get it open is as follows: Pull the latch open and spray WD-40 into the handle openings using the spray tube that came with the WD-40. You may need to repeat this. Note, when I use the word 'latch', I'm talking about the part you pull to open the door, not the lock, which is a separate part inside the door connected to the latch by a metal rod.
There are many ways to then hit the latch to jar the stuck hinge loose. To prevent damage, I folded up an old dish towel, placed it over the latch, and pounded it with medium force with a rubber mallet. It may take just a few hits, or it could take literally hundreds. Initially, the exterior latch will flop loosely. You can see if you're making progress by checking the latch periodically. It will gradually start to break loose and this will be reflected in restored tension in the previously floppy latch. The longer you hit, the tension will eventually be felt through the whole range of motion in the latch. Once full tension is restored, it will open the door.
The first time I did this repair, I simply considered it fixed and stopped working on it. Big mistake, because the locks stuck again in just a couple months and took a lot more work to get open the second time. These latches are cheap and easy to replace (check rockauto.com or other sites - I got my new latches for $12 each).
You must be VERY careful when changing them, otherwise you'll be opening up the door, which isn't necessary if you do it right. To change the latch - remove the two grommets from the door jamb at the latch. Use a 10mm nutdriver to remove the two nuts holding the latch. Care must be taken not to drop the nuts inside the door, but the nuts are angled slightly upward, so gravity is on your side.
Next, CAREFULLY pull the latch out of the door the minimum amount necessary to clear the opening and expose the latch rod that runs from the latch to the lock. IMPORTANT: Before removing the rod from the latch, get a pair of small locking pliers (long hemostat or needle nose vise grips) and attach it to the rod about 1/2" below the latch to hold it in place. This is necessary because once you remove the two nuts holding the latch to the door and the nylon grommet that attaches the rod to the latch, the only thing holding the rod in place is gravity. If you lift the rod more than about 1" while doing this work, it will disengage from the lock inside the door. I learned this the hard way on my first door and actually dropped the rod to the very bottom inside the door. Once the rod is secured with pliers, remove the rod from the nylon retainer clip on the latch and pull the latch free from the door. Installation of the new latch is the opposite procedure.
The second door was a breeze to fix since I didn't have to remove the door panel to retrieve the rod - the whole replacement took less than 10 minutes.
Oct 15, 2012 | 2001 Nissan Pathfinder
Rear passanger door on ford f-150 extended cab is stuck and won't open. what to do?
THE BAR THAT PULLS THE LATCH OPEN HAS PROBABLY CAME OFF INSIDE THE DOOR. HAVE TO REMOVE PANEL FROM DOOR AND REPAIR ROD
Jul 14, 2012 | Ford F-150 Cars & Trucks
2002 Chevy S10 Third Door Won't Open
I have a 02 s 10 with a stuck bottom 3rd door latch. I took my seat balts loose removed the door panel,also removed the plastic latch yoy use to open door, the top latch was alredy opened and I put a needle nose vise grip on the lever going to the bottom I used to much and broke the little plastic retaing piece that holds the lever.I looked inside door with light saw my latch was in open pos and took pry bar to pry botton door from inside,once opened i used a 10 mm 1/4 in drive to take out 4 bolt's to latch.removed latch placed in vice and heated with burnsomatic torch,the latch is coated with a plastic so i burned it all off with vice grip on the lever to open and pliers the work the part that catches door striker I kept working it until it freed up then put antu seige on put back in truck. I recomend buying a new latch and put anti seize on it. that's my plan but at least it's working for now. or get a good used one from a junk yard. you can e mail me at [email protected] for ant Q's
May 21, 2010 | 2002 Chevrolet S-10
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
453 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
