Theresa Lawrence Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear 1 tab from a IBW typewriter? - IBM Office Equipment & Supplies
pictureman4u
Level 2:
  • Expert 132 Answers
  • Posted on Apr 01, 2010
pictureman4u
Expert
Level 2:
Answers
132
Questions
0
Helped
43954
Points
329
Deavephysical.info/low-tack-lift-off-typewriter-tape-clear.asp
I hope this helps you..
HOW DO I CLEAR ALL TABS ON IBM WHEELWRITER 3500 BY LEXMARK TYPEWRITER
Tab all the way to the right, hold down the tab clear key, press return.
DickyO
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
Can't clear tabs on IBW wheelwriter 2000
Space all the way to he right, hold down the T Clr key on the Left side of the keyboard, press return. If this dosen't work you have a key board problem.
DickyO
Swintec 4040 Tyepwriter
Individually tab to the tab, press tab clear. All tabs, tab to the right,
hold tab clear and touch return.
DickyO
How do you clear the tabs on a sx4000 typewriter?
I'm not positive but generally speaking tab all the way to the right, hold down the tab clear key and press return. To clear a single tab,tab to that point press tab clear key.
DickyO
I have a swintec 8016. please tell me how to clear the tabs that are set so that i can set new ones.
Space all the way to the right press and hold the tab clear ket, press return, all the tabs should clear. Space to the points that you want tabs and press tab set. To clear an indivual tab tab to that position and press tab clear. DickyO
1helpful
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
4helpful
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
1helpful
2answers
Reset Tabs on an old IBM Wheelwriter 6 Typewriter ?
Tab to the tab you want to clear press tab clear (t clr) lower left side of the keyboard, to clear all tab all the way to the rt. press and hold tab clear and touch return.
DickyO
Lexmark Wheelwriter 1500 Clear All tabs
If you want to clear just one tab to it and press tab clear. If you want to Clear all the tabs tab or space all the way to the rt. oress and hold tab clear and press return.
Hope this helps
DickyO
Top IBM Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
