How do you open the top of a laserjet 2600n? - Office Equipment & Supplies
Posted by info61505 on
Anonymous
    Sergeant:
  • 148 Answers
I think you will find this manual very help-full
HP Color LaserJet 2600n Service Manual
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Posted on Apr 01, 2010
Really bad copies
Check your toner levels. If OK Restore default settings on Printer
Jul 30, 2010 | HP Color LaserJet 2600n Printer
2600n:phantom repeat
most likely the fuser. maybe transfer.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If the page is clean no ghosts the problem is most likely the fuser.
Mar 21, 2009 | HP Color LaserJet 2600n Printer
Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Nov 12, 2008 | HP Color LaserJet 2600n Printer
Door open warning at power on
open the door and look on the Left top the switch is there, probably needs adjusting
Sep 08, 2008 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Laserjet 2600n
maybe you have not close front cover properly. or the cover you just open after it jam.
Jul 15, 2008 | HP Color LaserJet 2600n Printer
Print Problem in 2600n and Laserjet 1000
Just install 2600n manually and define as USB Virtual printer port!!!
Jan 24, 2008 | HP Color LaserJet 2600n Printer
122 people viewed this question
Marvin
Marvin
