PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, You need to go to your Service providers, web site & navigate your way to the specific PUK details for your mobile phone network operator. Usually you have to Register your phone to get a PUK code.
SOURCE: Forgot Password for samsung Mobile E250
hi there! you need to press *2767*2878# and if that dont work try *2767*3855# but beware! you wil loose all information. So do a backup first.
SOURCE: forgot password
This will reset the phone's settings to factory default. Use this at your own risk:
1. Switch off phone.
2. Remove the sim card.
3. Turn on the phone.
4. Type *2767*2878#
5. Use 00000000 when it ask you again for the phone lock code.
SOURCE: my t mobile tap is user password locked i forgot
I found this answer at Howard Forums from a user named JHDreamer
1) Power up device and when prompted to enter password enter 1234
2) Press end key twice at the password error screen
3) Enter dial pad screen
4) Type in *1673492846 then press down on the D-pad
5) Select menu option 8, 1 , 1.
6) Let device reset and your done =]
Or
If you don't want to do a master rest, do this.
Thanks to BillA*
1. Connect the phone with a serial connection such as NSPro box.
2. Using CDMAWS read the following addresses:
T469/559 - read 0x023C0000-023D0000
A887 - read 0x02570000-02580000
3. Find the lock code in the bin around the string "36245"
