Question about Alpine CHM-S630 6-Disc CD Changer
Alpine CHM-S620 6 Disc CD Changer Components
I recently bought a 1989 Ford Bronco. The in dash radio had been stolen from it a few weeks earlier, Under the back seat was a Alpine CHM-S620 6- Disc CD Changer and in the overhead console a CHM-S655RF Control/Select unit. The wiring leading to the dasboard on both devices has been cut however the CD Changer does unplug from the existing wire. Can you tell me what device would have been installed with these 2 Alpine devices? And possibly what kind of connections or wires I may need to restore the system. Thankyou , Keith D
Posted by joebearnm on
Anonymous
    New Friend:
The installation manual can be found here:
http://safemanuals.com/user-guide-instructions-owner-manual/ALPINE/CHM-S655RF-_M
Is the FM modulator unit still present?
Posted on Apr 16, 2010
  • Anonymous Apr 16, 2010
    I had one of these fitted to my 99 ford falcon when I bought it in 2000. The changer, the head unit and the antenna all plug into an FM modulator (about double the size of a packet of smokes) that then has a lead that plugs into the car stereo. If the FM modulator is there then you have all the parts, you may just need to replace a couple of DIN leads and the car stereo of course. Check my previous post for the link to the installation manual.
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Posted on Apr 01, 2010
6 disc cd changer wont read cd
have you tried factory (store bought) CD's or changed all of them out
Nov 06, 2013 | Alpine CHM-S620 6-Disc CD Changer
CHM-S630 6-Disc CD Changer: what is the best 6 disk cd player to connect to an...
hi how are you , my cd changer s630 recently just started to eject the whole cartreidge i push it back and its makes some nosies and then the same ejects it
May 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
Alpine CHM-S601 cd changer acts like there are no disc's.
Disconnect the power for 3 minutes and then connected again if you still acting the same way does mean to see the changes Is broken
Jan 05, 2018 | Alpine CHM-S630 6-Disc CD Changer
Can a CHM-S601 hook up to a 1997 ford F-150?
It won't work if the radio doesn't have a cd changer input. The radio/receiver has to have been designed/programmed to interface with the changer since that is what the changer is controlled through.
Jan 08, 2010 | Alpine CHM-S630 6-Disc CD Changer
My Alpine CHM-S620 CD changer broke down and so I
Check out www.crutchfield.com . you can cross-reference your vehicle model and they will show you what is available for your vehicle. They carry a large inventory and I have purchased from them several times.
Sep 26, 2009 | Alpine CHM-S620 6-Disc CD Changer
I've had my Alpine CHM-S620 6-Disc CD Changer for approximately 6 years, bought at Circuit City. Beginning 3 years ago it began to turn off and on, initiated by pushing the track change button for CDs or...
Well your changer has seen better days, but not dead yet. It can be repaired, but it's gonna cost ya. There are pro's, and con's in the debate between repairing, and buying new, but that's for you to decide.
Alpine makes some of the best, and longest lasting product's in the car audio industry, so getting it repaired isn't a bad idea, but the cost of changers has come down ALOT in the last 6 years so it may not be any cheaper to get it fixed. If you like the Alpine brand, then fix the one ya have, because Alpine no longer manufactures CD changers.
Aug 09, 2009 | Alpine CHM-S620 6-Disc CD Changer
Which radio for land rover
Usually an Alpine unit.  Try ebay.
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
Chm -s620 cd changer not loading cds
I've got the same problem with my Alpine changer. It seems like a widespread problem, but known cause or solutions.
Apr 03, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine and gamma in vw
YOU WILL NEED AN INTERFACE TO CONNECT THESE UNITS WHICH YOU SHOULD BE ABLE TO PURCHASE FROM YOUR CAR AUDIO RETAILER OR SEARCH THE NET
Dec 03, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 Tape/CD button inoperative
Dont know Steve, i am no fundi with electronics but could it be that your system is set up for the steering remote, or perhaps not activating because of a wiring or button contact issue ?
Hope you get it sorted out.
Richard.
Oct 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S630 6-Disc CD Changer Logo
1,110 people viewed this question
Top Alpine Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
