Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Download the manual for *********** board and it will tell you. If you are running windows 32bit I think the max usable is 4GB. If you are running a 64 bit OS then then it is more. The manual will give you max ram per slot and what slot to put them in.
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model
Brand
ASUS
Model
M2N68-AM SE2
Supported CPU
CPU Socket Type
AM2+/AM2
CPU Type
Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Chipsets
North Bridge
NV Geforce 7025 / nForce 630a chipset
Memory
Number of Memory Slots
2×240pin
Memory Standard
DDR2 1066
Maximum Memory Supported
4GB
Storage Devices
SATA 3Gb/s
SATA RAID
0/1/JBOD
Onboard Audio
Audio Chipset
Realtek ALC662
Audio Channels
6 Channels
Onboard LAN
LAN Chipset
RTL8201CP
Max LAN Speed
10/100Mbps
here just for your reference: your product specification, click on specification and look for Motherboard Chipset , and here supported list for that chipset.
If all of your memory slots are used, you will need to remove the memory that is currently installed in order to increase your RAM. It appears that the T180s were originally configured with 256MB, but they are expandable to 4GB. If there are 4 slots (I couldn't find any documentation with images), you can use a maximum size of 1GB modules for each slot. Just remember that if you are using a 32-bit operating system and you upgrade to 4GB of RAM, you will not be able to use all 4GB. The BIOS will report 4GB RAM, but the operating system will only see approximately 3.4GB.
Max speed supported for your mobo is: DDR2-533 You will have to buy (4) 1gb sticks (2gb sticks not supported) To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps! Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory
Maximum Memory
4GB
Memory Slots
4 (4 banks of 1)
non-removable base memory
0MB
Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE:
*Actual available memory may be less w/o 64 bit os
