Notebook receives following message: ''You might not be able to access the internet or some network resources. This occurred because the network did not assign a network address to the computer.'' Last week it was working fine. D-Link router says computer problem. Notebook OK using cable. Wireless reception is ''Excellent.'' Product is Raylink 802.11g Mini-USB 2.0 Wireless Network Adapter #2 not Belkin but Raylink not a choice.
service.msc is not recognized. Went to msconfig>>Services & unchecked DHCP. Restart. Then recheck DHCP. Restart. Trouble not corrected. Wizard does not correct. Reset D-Link router. Problem remains. Restored notebook to a previous date. Not the answer. I now get a message "Windows was unable to find a certificate to log you on to the network Murchison"service.msc is not recognized. Went to msconfig>>Services & unchecked DHCP. Restart. Then recheck DHCP. Restart. Trouble not corrected. Wizard does not correct. Reset D-Link router. Problem remains. Restored notebook to a previous date. Not the answer. I now get a message "Windows was unable to find a certificate to log you on to the network Murchison"
You can't post conmments that contain an email address.
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following: Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
On setting up or make network connections on a
resources.
Here's How:
often a false error report. If your network access is non-functional. continue
following steps.
if it necessary.
following steps.
additional support.
support.
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets If you can't connected to the internet,then that network probably doesn't has an internet access on it
Check the information that came with the router or
access point to find out what connection mode the device is set to. The
mode should be either ad hoc (when devices communicate directly without going through a router or access point) or infrastructure (when devices communicate by going through a router or access point). Make sure the setting in Windows for this network matches the setting on the device. To check this, follow these steps:
Open the Command Prompt window by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Command Prompt.
Type netsh wlan add filter networktype=network type.
Where network type is either adhoc or infrastructure.
Did a bit of research for you on this and came across a ten step set of instructions which should hopefully correct, or at least narrow down your problem:
Is your wireless network secured ? IF secured then make sure that you are typing the correct network key / password. if you are not sure about the wireless settings of the router then open the set up page of the router and check the wireless settings. You are getting the message " connected to the access point but internet can not be found ". Are you using Linksys wireless adapter ? What is the operating system ? If it is Windows XP then use windows utility to connect to the wireless. Click Here for step by step instructions
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
Ok, you have several options. Go to a website such as bestbuy.com. Type in linksys and look of wireless access points, wireless usb adapters or a wireless desktop adapter. I would go with the third one.
