The stereo/mono switch in most amps mearly feeds one channel to both channals when in mono. However it does mean that the Power Transistors (or whatever does the main output) is working on both channels. Therefore the dead stage is in the pre-amp part. Remember that the two channels will have the same parts as each other. The advantage is that one will have working parts and the other wont. So you can compare the two channels with voltage tests, using a multimeter.
