Question about Samsung SyncMaster 2333HD 23 in. LCD TV
Before scanning for channel, check to see if the Antenna input is set to Cable or Antenna. If you have rabbit ears or and outside antenna then set it to antenna. If you have cable then set it to cable. Then rescan for channels. If this has already been set then the next step is to check the antenna or cable feed. If possible plug the antenna or cable feed into another TV that is known to be working correctly. If it is capable of receiving digital channels then the problem is likely the Samsungs ATSC tuner and will require service.
If neither TV is getting Digital channels then I will need more info on your antenna setup and where you are located. I am a pro on TV antennas and reception.
Hope this helps
Have a great Day
Posted on Mar 31, 2010
Make sure the tuner is set for Cable and not broadcast...accordianman
now have just digital antenna to get local channnels. I cannot seem to set this up, as only choice allowed is TV, not AV Receiver (under Source List). Can you help with with settings to use under Menu function? ... very frustrated right now :/
seems some of my question was cut off; am trying to set up channels on my samsung syncmaster910
