Question about Timex 27191 Wristwatch
Cannot reset days on my Timex Indiglo WR 30M and want to know how. I can change the date and change the time, I just cant seem to find the setting on the stem to change the date without having to wind it for several days worth of time.
Posted by jimpaz67 on
Arturs Kalnins
  • 2,338 Answers
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Posted on Mar 31, 2010
David Hellenga
    New Friend:
I just bought a Timex Indiglo WR 30M watch and thought I had the same problem. I looked around the web and found that the first position when pulling out the stem is almost imperceptible, but it is there. Pull the stem ever-so-gently and you should feel a slight resistance. This will be the date advance position, and the next and last position is the time/day setting position.
Posted on Jan 04, 2013
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
How to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
Mar 06, 2011 | Timex 27191 Wristwatch
How to change the analog date on a timex indiglo WR 30m watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, plz.
Feb 18, 2010 | Timex 27191 Wristwatch
I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Dec 06, 2009 | Timex 27191 Wristwatch
TIMEX INDIGLO WR 30M
I pulled the stem out, and presto. Thanks for nothing!
Jun 12, 2009 | Timex Watches
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
Sep 12, 2008 | Timex 27191 Wristwatch
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 | Watches
Timex 27191 Wristwatch Logo
2,588 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
