Question about Kenmore 77554 / 77543 Bottom Freezer French Door Refrigerator
Ice forms around fan and makes a loud humming noise
Fridge is 3 yrs old. I've had Sear out about 5 times in last 3 years. because of this problem.it seems like a design problem . never had a fridge with this problem. can't afford warranty or sears coming out to chip ice off. sometimes ice does melt before repairman shows up
help!! this is a Trio fridge with french doors and freezer draw on bottom
Posted by dltrielo on
Carl Schulzetenberg
  • 1,543 Answers
It's probablly caused by air leakage through the ice room fan electrical connection inside the freezer. Behind the back wall inside the freezer, the icd fan is the fan that blows air up to the in-door icemaker. The plug on that, into a molded plug on the back of the feezer compartment, is a red plastic part with three wires in it. Try filling in around the wires and the red plastic with a bit of silicone. (if you replace the ice room fan, the new plug comes with a rubber filler which seals this spot). (PS. Next time, avoid Sears)
Posted on Mar 31, 2010
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
I've had my samsung bottom freezer counter depth fridge for just over a year and in the last 5 to 6 months it's started to periodically make a very loud humming noise. Should I be concerned that there is...
The freezer compartment fan may have Icing or the motor is going.....Remove the trays and remove the rear cover. The fan and Freezer evaporator are behind that cover.
The fan doesn't run all the time.
If you have an ice maker it too can make buzzing sounds. Just turn off the Ice maker to eliminate it as a source.
Here's a link to the service manual for the 215
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 08, 2010 | Samsung RB215LASH
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge making a humming noise every 3 min
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 77554 / 77543 Bottom Freezer French Door Refrigerator Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
