How to disable odometer
By doing this is illegal, there is really no reason to do this !
only if you are trying to cheat your lease, or the next person buying your car,
I could tell you, its easy to do, ok here is how you do it !
To do this to keep the mileage low or not adding up.
What you do is, put your key in the ignition, turn it to the on position ten times, in a row not starting your car, then within 30 seconds get on of your car and place key in your door lock, turning it to the lock position, then take your key FOB and press the lock button 3 times with the key still in the lock cylinder turned to the lick position.
Wait 5 minutes, then disconnect your battery and wait 5 minutes, then hook your battery up again. If you did this right, you have now just overider your computer, to disconnect your mileage, if not repeat.
Now to have your mileage start to record again, place key in your ignition, turn to the on position, not starting your car, do this 5 times, after this is done, on the last turn leave it in the off position, press and release your unlock button on your key FOB 3 times, then disconnect your battery for 5 minutes and connect it back, now your mileage with record now.
Remember I told you this is illegal to do, there is really no reason to do this
