Epson Stylus Photo R1800 InkJet Printer Logo
Anonymous Posted on Mar 31, 2010
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
  • Anonymous Apr 01, 2010
    ronrejjr
    Tried running maintenance and head cleaning twice. Still clogged.
Ron Johnson
Level 2:
New Friend:
  • Expert 127 Answers
  • Posted on Mar 31, 2010
Ron Johnson
Expert
Level 2:
New Friend:
Answers
127
Questions
0
Helped
61438
Points
365
Your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
2helpful
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
My NX100 leaves white, skipped lines across the print.
dude your cartridges are about to finish. Kindly replace them with newer ones. you can print clearly
My epson R1800 printer sometimes ejects the paper to soon
I solved this problem by wedging a piece of cardboard in the slot next to the on-off switch. This stop the printer from cycling during the printing due to vibrations.
I have an Epson Stylus R1800. How do I print bleed with it?
When you go to print, adjust the margins to zero. If it states you are printing outside the printable area, choose IGNORE.
All the setting pages have changed language
My guess is that you have a language specific version of the driver that does not contain the English language files.
I suggest getting the latest driver version from Epson and then uninstall the old version before installing the newest.
If this still doesn't work, contact Epson...
Epson Stylus Photo R1800 Won't print anything but head utility
If you are using Mac, make sure you choose or add the correct R1800 printer ( USB or Firewire ) to the Printer list in order for the printer to response. Hope this will help
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Epson Stylus r1800 not working on I mac
I have posted the solution on the problem page. This does work but I don't know if anyone will see it!!
2helpful
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
