Question about Vacuums
Lost suction from cleaning dyson roller brush
I cleaned the brush on the dyson animal and put the vaccuum back together but now it lost its suction
Posted by makpula on
Chris Jones
  • 438 Answers
This is actually a very common problem that we see for repair on Dyson Vacuums. Usually what happens is that the vacuum doesn't loose suction like most people think. You can test this by feeling the suction power on the hose. If you have suction coming from here, then most likely the machine isn't clogged.
What happens is that the bottom soleplate on the vacuum cleaner can easily be re-installed the incorrect way. If this happens the brushes on the vacuum cleaner can not even hit the carpet, which makes the vacuum feel like it's not picking up, but when the suction is tested from the hose it has plenty.
We see a lot of Dysons come in for repair with this problem. The bottom plate is not flush with the rest of the vacuum cleaner. Here's a picture of what an improperly installed bottom soleplate looks like:
When the bottom plate is put back on the vacuum, you should make sure that the bottom plate (the purple colored part in the picture) is flush with the agitator housing tray (red part in the picture). If not, the brushes will not hit the carpeting, and the vacuum won't really pick up anything.
This is how a correctly installed bottom soleplate should look like:
This should be the first thing you should check on your vacuum cleaner as it's the easiest and most common solution. If this doesn't fix your Dyson, please just use the Clarification Request form, and let me know which exact Dyson model you have, and whether the vacuum has suction power from the hose, whether the brushes turn when set to the carpet setting, and how old the vacuum is. I'd be happy to try and further diagnosis the problem with you.
I hope that this was helpful to you. If it helped you, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Mar 31, 2010
My dyson dc35 animal brush spins very slowly. Brush is clean and hair free, could it be the small motor
There shouldn't be a motor in the brush. The brush is powered by the suction on the hose. Check the suction on the hose. The vacuum itself might need to be cleaned. If the suction is a problem and you have cleaned the vacuum I would contact dyson support to see if they can replace your vacuum. http://www.dyson.com/support.aspx
May 23, 2016 | Dyson Vacuums
My dyson dosent have much suction and not picking up
Check if the roller brush is turning, if not you may have a snapped belt,, caused usually by the roller brush jamming so is it free.Then suspect a blockage in the pipe or base ducting. I would also make sure the filters are clean , replace them if in dought.
pete
Nov 29, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I cut all of the hair out of the bottom of the spin-brush on the Dyson Upright Animal Vacuum. Now I dont think I can get the brush back in there correctly. If I squeeze it in there (which it is a VERY...
Check the roller ends for dirt build up, they pull off and you should be able to clean them out. The roller should just go back into place if pushed together.
Oct 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc17 animal will pick up via the hose attachment but there is no suction when you use the regular vaccuum on the floor - you can hear the difference in the suction once you put the floor part down...
Hi its Darran at Dyson.
Check that the brush control dial is in the centre position when upright and then moves forward when the head is released. If the brush bar is still not spinning when switched on in the vacuuming position, check the base for blockages and remove any threads or hairs from the brush bar as outlined in your user guide or on our website.
If you are still having difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson absolute 17 animal smells like its burning when turned on also has terrible noise...nothing wrong with belt already checked it..so what's going on
I had the same problem with my DC15. With the brushes going it smelled like burning hair (bad). I had cleaned the brushes many times and it didn't seem to help. I even took it into a Dyson authorized repair shop and they couldn't find anything wrong with it. As a last resort I called Dyson 866-693-9766 1-866-My-Dyson. I was on hold for about 15 minutes before getting a live person. He had my problem diagnosed in literally 1 minute. I had hair wrapped around the spindle, inside the brush/roller mechanism. He walked me through taking apart the brush mechanism (super simple only using a quarter). There was a TON of hair crammed around the spindles and inside the brushes. All wrapped very tightly. I hung up with him to do the cleaning. It took some time and I had to use tweezers to get inside the rollers/brushes. But I got it all, put it back together (which was really easy) and tested it out. No burning hair smell at all. FIXED!
Nov 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
610 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
