Belkin (F5U273) Logo
Posted on Jan 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Docking station crashes PC - DELL XPS M1330
I am trying to install a BELKIN F5U273 docking station on my DELL laptop XPS M1330 with Windows VISTA Business.
After installing the software the PC starts to malfunction as I loose internet , cordless keyboard & mouse the BIOS is A15.
What could be the problem?
Joseph Wright
Level 3:
  • Belkin Master 1,729 Answers
  • Posted on Jan 29, 2018
Joseph Wright
Belkin Master
Level 3:
Answers
1729
Questions
Helped
454664
Points
5127
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Feb 06, 2007
SOURCE: problem with laptop connection
KVM's work best when you are using the same or similar type of hardware however there might be an issue with your video card interfacing with the KVM. I would switch the Video cables and see if the problem moved or disappeared. If the problem moves, then I would suspect the video card is the culprit. Since many problems can be traced to software compatibility issues, I would check to see if there is an updated driver for your video card and or your monitor first. If the problem disappears it could possible be a loose cable connection on the destop PC or the KVM itself. I would also try a different set of cables.
Anonymous
  • 35 Answers
  • Posted on Sep 22, 2007
SOURCE: Belkin wireless optical mouse
download the driver here: http://www.belkin.com/support/
Anonymous
  • 89 Answers
  • Posted on Mar 19, 2008
SOURCE: installation software for belkin F1U201
Hello, Try this link: http://web.belkin.com/support/article/?lid=en&pid=F1U201&aid=6052&scid=1 Hope this helps
Anonymous
  • Posted on Sep 16, 2008
SOURCE: Belkin F5D7230 4 not working with vista
try and run it in application compatability mode set to 98 or xp.
Anonymous
  • 221 Answers
  • Posted on May 16, 2009
SOURCE: 2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Updated laptop to windows 7....need updated software for targus acp50
The Targus ACP50US Docking Station does not seem to have an updated driver for Windows 7. You can attempt to install the docking station using the driver found at this link but that may not work as it is only meant to be used for Windows 2000, XP, and Vista. I'm sorry but if that driver does not work, the docking station will not work until there is a new driver for Windows 7.
Thank you for using FixYa!
What typically breaks on a dell pro3x docking station? Cosmetically the docking station looks like new. I tried a good power pack too. When dock the laptop with it off, the light on the eject button...
Do you have the driver for the docking station installed? If not, visit www.dell.com and search for the model number of the dock and then download and install the driver.
Lapto dell xps m1330 just pressing on button to start blank screen appears no bois no windows logo no any things
this is VGA card issue u need to repair it.. if u have any idea about reworks station u ca repir at home  .. for further details u can contact me @ [email protected] Thanks
Dell latitude D410 wont boot up when hooked to docking station can not use keyboard or mouse
Sounds like a compatibility issue between your Dell and the Docking station. I would say make sure the software for your docking station is installed properly, and update the software before connecting again.
2answers
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
2answers
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Dell Palm doesn't sync when laptop on docking station
it get start but doesn't show any think on display and onlyn just it shows allign screen
No internet when docked.. needs network controller
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
