Phone sometimes takes forever to charge. I have it plugged in at night and it is still charging the next morning with no to little progress. Sometimes if I shut down the phone and restart it, it charges normally. Sometimes when I unplug the phone, the phone still thinks it is charging. I bought a new battery a few months ago and experience the same problem.
Re: Phone sometimes takes forever to charge. I have it...
Hey bro
your problem is in the hardware, the CHARGE IC problematik. you need to go somewhere close to you so some one will change it for you. and than all will be OK.
memeh
Fixphone
Hello. Begin by checking the cord, specifically the end you insert into the car socket. that end has a fuse in it. You can easily unscrew it to check the fuse. Sometimes, also, that tip comes off so the plug has no fuse and will not charge the unit.
If the plug is ok, remove the tiny frame around the screen with your fingernail. Under that little frame you will see the reset button. Push it.
Not sure how I eventually got it to work but the camera charged up ok after connecting it to my pc via the usb cable and then deleting some empty folders and a few remaining photos............
make sure that your charger is not bent, i had the samd roblem sometimes you just have to get a new charger or just get that one to position right so that it will charge the phone
I finally find a way to stop this problem from occuring : never leave your phone on the charger with the battery isnt empty !
I know this sucks because what best place to put your phone at night than its base. But try it and it will work (unless your battery is already damaged). In the morning when i go to work, I charge it for 8 hours, then when I come back, I take it off the charge until next morning.
