Question about Kyocera Mita KM-1815 All-In-One Laser Printer
KM 1500 Error c-6 000 error
Shows Error C-6 000 error
Posted by rabindh on
Anonymous
    New Friend:
Kyocera km1500 problem of 000 ,c-6
Posted on Nov 14, 2010
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Getting error messege E07
KM-1500 E-07 error
"E07" appears on the copy quantity / magnification display, The size of paper registered in the default settings is different than the size of the paper actually used. Check the paper size. Pull out the corresponding drawer and then push it back in to delete the error indications.
Sep 09, 2011 | Copystar CS-1500 Copier
Kyocera Mita KM-1500 shows flashing c-6 and 020 Pls help
check the fixing unit thermoswitch,thermistor & heaterlamp one of them is the cause of error
Nov 22, 2010 | Kyocera Mita Office Equipment & Supplies
Can not find the waste toner bottle on km 1500
Hello sir; Open the front door, on the left handside have a white plastic box just next to the toner cartridge.
Sep 30, 2009 | Kyocera KM-1505 Copier
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
OP error
Have you added toner recently?? If the copier is just running and then shows code you may have to install a new toner. The soft ware is different in different contries and the codes are all not the same meaning. I would cheak the toner first..
Apr 14, 2009 | Kyocera KM-1505 Copier
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Copier giving error
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
Sep 06, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
1,728 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
