I want to know if I can use the "eject" drive (normally used for Windows ME users -- as the manual shows ) option for the "removable F" drive in Control Panel?
As my lastest reinstall has caused a problem with using the WIN XP Scanner and Camera Wizard Autoplay feature..
Basically, will this help reinstall the Fuji FinePix 2650 camera software and driver and allow me to do a fresh install?
I really do not want to use the FInePixViewer software upload my digital pics from my camera -- I want to use the AutoPlay WIN XP Camera Wizard again, as I did before, but it is giving me trouble and for some odd reason will not NOW find my camera anymore -- nor load up my pics from the digital camera. The Wizard says "something else is using the USB port or files" ??
Plus, there is an unknown "Other device" Yellow warning Q? Mark listed in Device Manager - in System files, which has listed under it what is called Multimedia Audio Controller" which I have No Clues what it goes with -- except it says its a (Code 28) and says to reinstall the drivers -- but it cannot find it rhrough the Hardward Wizard.
So I am conplexed as to how to solve these issues. Can anyone tell me!!
Can I safely delete both of these devices in System Properties ---and could these devices be related to the Removeable F drive - as the Fuji - FinePix manual says that it places an Removable Disk F: icon in Control Panel?
Are you telling me that I need a new USB cord? My problems since 2010 is not the USB cord -- it the fact that the FUJI 3.0 Driver was placed in the Windows TEMP file area and Windows, and once I found its location - it says Opens WIth "Unknown device." So maybe another USB cord would help, but I do not see how that helps me with the Driver being listed in my temp file - issue. And since the time of this post in 2010 -well I had to find another way to install my pics, pretty much as I described in my lasted post. The USB cord must be fine if I can use it to transfer my pics - from within My computer and load them that way into the conputer IMHO. However, I see that You are showing [new] smart cards too! So, what you are attempting to tell this old bird-- [me] in other words, you are saying that I put my smart card in this smart card reader instead and load them that way? IF SO -- then can you flip the pics before you load them to the desktop, and or does this reader changed them to a jpg pic file -- or are they stil DSC [read only] once loaded? As I should of mentioned in my second post -- that I did not see [or HEAR] the "found new hardware" icon come up on the taskbar -- with the uninstall -reinstall of the software, and I believe this is due to the FUJIUSBDRV [3.0,0,0] going into the Temp folder - instead of its proper place - where ever in the system files it is supposed to be placed? Regardless, I will try your suggestion once I can get to Walmart again. Thanks posting your solution.
