Question about KitchenAid Food Mixers
No power after replacing worm gear in Kitchenaid KSM90 Mixer
I replaced the worm gear on a Kitchenaid KSM90 Stand Mixer...was very happy that everything went back together, no leftover parts, everything seemingly in its place...but then, no power. I saw a post about the motor brushes but had never touched those. I checked them after the fact anyway and they appear to be in properly, with the concave face appearing to make proper contact. Any other ideas of what might have happened. Your help is greatly appreciated.
Posted by steverapp on
Bob Hewitt
  • 130 Answers
Remove the rear cap from the unit. Power comes in from the black wire with the white being common. Hold a voltmeter lead on the white and check for power on the black. Power goes across the bottom of the speed control unit via a buss bar. Check for power on the right side, I think it is a red wire (may be a white one). Power is taken into the motor via that wire, goes thru the windings and the brushes and then out the other brush wire and back to the board. Check for power on the return wire. If it is dead then either the windings in the motor are burned out or one of the brushes is dirty and needs to be cleaned and reseated prpperly [note there is one and only one way the brush goes in!!!! Install it incorrectly and the brush will not touch the commutator.
Try that and see if it runs after cleaning the brushes.
Posted on Apr 01, 2010
  • Joshua Holmes Oct 09, 2010
    Really appreciate this answer, HOWEVER, can you please specify which way the the brushes go in? Thank you
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
What model kitchenaid was made in december of 1973?
3 PointsQuestion about KitchenAid KSM90 Ultra Power Series Stand Mixer
Isn't KSM90 the model number?
Aug 03, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
No power to my kitchen aid mixer
please i need help kitchen aid mixer i have no power
Jun 27, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
KSM103 won't run
I had removed carbon brushes and when tried to start nothing happened kept removing brushes it eventually started
Dec 14, 2007 | KitchenAid KSM103 Professional 5 Series...
Kitchen Mixer not running correctly
you will have to spend some money to have your machine fix it has worn parts.need to be serviced call in the repair man to slove your problem.goodluck.
Apr 04, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
577 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
