Question about Karcher 2500 PSI Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
  • Marlena Marlena
    Marlena Marlena Jun 27, 2015
    Try to remove the pump(4 bolts), then start the engine...Most likely the pump is seized.
snapon1270
    New Friend:
Honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Posted on Jun 05, 2011
Darc Nelson
    New Friend:
New honda pressure washer, had it maybe 2 years and have used it maybe a total of 3 hours, i was using it yesterday and it was running fine and it shut down like i turned the kill switch. Has oil and gas but seems to have lost compression. engine is a overhead cam GCV 160 Honda, Troy Built model
Posted on May 17, 2010
Honda gc160 engine on 2500 psi washer, no spark?
new spark plug? flooding may have fouled the old one.
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
Aug 08, 2016 | Honda Garden
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
I have a Honda GC160 5hp that I just rebuilt but will not start
did you check the piston to bore clearances? did you check the ring end gaps? did you hone the cylinder and check it for roundness?
Jul 08, 2017 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Oil leak appears to be from pump, not engine, GC160. What oil and how much should be replaced. what might be source of leak
some pumps have a side glass and oil should be half of side glass and depends on manufacture oil is different if general pump you can use 30w non detergent
Aug 24, 2010 | Honda Pressure Washer PSI 3000
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
2,764 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
Bruce Robin
Are you a Karcher Garden Expert? Answer questions, earn points and help others
