Question about Jabra BT250 Consumer Headset
My earpiece wont charge i just opened the box and the blue light flickers once and it wont charge
Posted by johnnylaw71 on
John Street
    Guru:
  • 513 Answers
Your charger could be bad. Headsets do not usually show any sign they are charging. Leave it for 2 hours on charge then check the charge level as it shows in the owner's manual.
Posted on Mar 31, 2010
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Good luck from Headsets Direct!
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I am trying to pair my explorer 240 bluetooth with a new sanyo incognito phone. But the phone does not see the bluetooth. What is the problem?
have your phone bluettoth enabled and ready to search for devices
Once it finds it simply use 0000 or 1234 as the code when the phone asks you
Hold down the power button on the earpiece uuntill you see flashing lights (either blue/red or blue/green and let go of the power button
Make sure the earpiece is fully charged before doing this as it may fail otherwise.
Mar 16, 2011 | Plantronics Explorer 240 Bluetooth Headset
Earpiece won't link to phone anymore
Hi Josh,
there may be a battery or an internal antenna failure on your headset.
You might try re-pairing the devices if you can.
Jan 08, 2010 | Motorola Mobility H700 Wireless Headset
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Plantronics 200 earpiece
i have a plam centeo and i have a 220plantronic blue tooth but i dont have the key code is there way i could get it?
Jan 28, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Jabra BT250 Consumer Headset Logo
814 people viewed this question
Top Jabra Radio Communications Experts
Richard Schabler
Vincent G
Vincent G
aliasger yq
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
