Charger light does not come on so I don't know if the stylus is charging or not. Stylus charges on other charger.Charger light does not come on so I don't know if the stylus is charging or not. Stylus charges on other charger.
You can't post conmments that contain an email address.
Yes, because the voltage and amperage input to the charger is constant, so the board management dumps excess charge once the battery is fully charged. The battery cools, but the charger warms up. Mine does the same. It is a 15 minute charger, so the current is high.
Most likely the battery is too low and cant charge because the charger is faulty. First get a known working charger and try it to charge your phone, this being the easiest approach to start fault elimination process.
when possible ring the technician up and ask that question
if the charger is old getting hot would be possible to overheat on new batteries
also it is possible the new batteries are fully charged before the 8 hours if you have a volt meter handy or know someone who has one you could check the new battery's voltage
if battery's need more charge wait till charger cools .. re start the charge sequence
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean https://www.youtube.com/watch?v=8rZqYmPsZycthe charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL how to charge broken makita BL1830 Li ion battery
This is indicating the battery is too hot to charge, usually after coming off the tool right after some hard work. During the charging process the battey heats up so if you charge a hot battery, thereby making it hotter, you shorten the lifespan of the battery considerably. If you are getting a hot/cold pack delay indication on the charger, it should automatically start charging once the battery has cooled down sufficently.
try your sisters battery on your mobile. if it powers up and your charger isnt working on your mobile then you have an internal loop fault in the power section of the mobile that directs power to charge the battery. its a big fault and is far cheaper to replace the phone than to have it repaired.
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Decase by removing the eight screws on the back. Check the charging fuse isnt blown. You will find it on the underside of the square circuit board that mounts on the back of the charger port.
The Sidekick 3 is notorious for having the charging port go bad. New battery or charger doesn't help when this is the issue.
YOu can get it fixed for around 100 dollars or ou can get a charging cradle that has a spare battery charger. Since you have an extra battery it will work well for you. They are about 30 dollars from ebay.
