Sony Playstation 3 (PS3) Console Logo
Posted on Mar 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ps3 starts up, fan is very loud, red light flashes and shuts off
When my ps3 is powered on, the fan is very loud for about 10 seconds, then the green light changes to red and flashes and shuts itself off.
Anonymous
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Mar 30, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
145
Questions
0
Helped
26818
Points
424
Your most likely cause is the CPU or GPU is damaged due to over heating. This is usually not repairable. Red flashing lights are usually a bad hard ware warning. Try looking up flashing or fault codes for PS3 light patterns and check if any match up to the flashes you get. Another thing to indicate hardware failure is if it boots up at all. I'd like to give you better news but this is more then likely more an autopsy report then anything helpful.
2answers
My playstation3 stopped working on 23/5/10. very hot day. now it starts momentarily then cuts out within 1 second. red light flashes. then an amber/yellow light. help
your ps3 has a under powered fan... you will have to mail you ps3 in to get fixed.. they will give you a ps3 they fixed. The new ps3 will have a more powerful fan.. but it will bug the **** out of you.
1helpful
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
1helpful
Red flashing light and PS3 won't work
I have had this same probelm unfortnaully .. It sux , and after trying alot of different things and reading , and talking to sony themselfs seems only fix is $150 repair or a new playstation :( . . Have you noticed your fan is just loud and has like 3 stages of loudness? Thats what mine did , and i got the red flashing lights if not loud then anthor device in your playstation has stopped working sorry to say
Flashing red light
Go to you www.youtube.com and you may be able to find helpful videos on this. But if you bought it new it is under warranty and they will fix it. You just pay for shipping.
3answers
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
