OE is a drain motor error, or your drain hose is kinked, check to see if your hose is kinked on the back of the machine.
Once you check to see if the hose is kinked, press the power button on the unit, then hit "spin speed" and select it to "no spin", and then hit "play". This will manually set your unit to drain mode. If you still get this error, you will need to replace the drain motor on the unit.
