First connect your router to computer with ethernet cable.
Then you can access it with default link.
http://192.168.15.1 or
http://192.168.2.1
Type user as "admin" and password as "admin" or blank or "password" or 1234 then you can se configuration page of router go to wireless settings and enable WEP security add new code so you can connect with that code.
If you want to configure it you can do it with below method.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Save settings and restart router
Then connect internet service provider cable to router .Then you can use it wireless.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
SOURCE: Receiving request for Belkin PIN from Linksys Router
hmm you shouldnt recieve a belkin pin request when you are connecting to a linksys router
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: Lost Belkin Wireless G Router F5D7230-4
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
SOURCE: Belkin router won't accept PIN on new computer
Hi Friend,
You need to just disable one of the option in the router,please follow the below steps
1.Type 192.168.2.1,in the Internet explorer,You will get a belkin router setup page
2.on your left hand side click on Wifi Protected Setup(WPS),it will asks for password,leave it blank and click on submit
3.It will say WPS enable,change it to disable and click on Apply Changes
4.Now try to scan and connect to the wireless networks
Regards,
Ayyasam
