Panasonic PT-AE3000U LCD Projector Logo
Question about Panasonic PT-AE3000U LCD Projector
I have a pt ae3000 panasonic projector and it seems some dust has gone inside the lense, there are spots on the screen, what is the safest way to clean this
Posted by ramtintb on
3 Related Answers
Anonymous
SOURCE: blue spots on screen
Obviously this is not the first lamp you have replaced in you projector. These are great projectors however, the LCD panels expire quite quickly. You will find that the spots are related to the LCD panels needing to be replaced. This is not an inexpensive maintainence solution as the panels cost about $1500 each.
Posted on Jan 25, 2008
Anonymous
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
Anonymous
  • 36 Answers
SOURCE: PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
Posted on May 07, 2010
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
I'm am new at this forum. Please help. I've
Check first if/that all connections are connected as the should be. That in order go to the menu on your tv. Go to picture and adjust the brightness. K
I just replace the lamp in my projector and it is still darker in the middle of the screen. It appears there may be dust on the internal lense but I do not know how to get to it.
It seems that most everyone who owns the Panasonic PT-AX200U has this problem. I believe it is on the lens inside on the glass. I'm not sure how to get to it either. Maybe this forum will help.I'm going to read it now. http://www.avsforum.com/avs-vb/archive/index.php/t-1166504.html
2helpful
My panasonic hdtv seems to have developed a yellowish tint to the screen
Sounds like the polarizing film is burnt on one of the three colored lenses that are located next to the projector itself. In order to fix this this it is necessary to remove the ballast and projector units, then disassemble the projector housing to expose the lenses. there are green, blue and vermillion (reddish) lenses. the vermillion lense is the one that causes the yellow tint after it has been damaged.
searching for the pt-43lc14-k service manual (the 'k' version is the more complete one) will provide you with daigrams and such.
I am currently undergoing this repair myself, thus far we have disassembled the television and are waiting on new vermillion polarizing film in order to complete the reapir. Good Luck, it isn't too difficult. Just take lots of digital camera pics (for screw location and sizing) and you should be fine.
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
Hi:
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
2answers
Small spot on screen
you have dust on your projector, you should be able to take the screws out around the screen, lean the screen away from the tv, and wipe dust off the projector
1helpful
2answers
Blue spots on screen
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mehandi Husain ...
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
