I have a master schedule with different projects inserted into the master schedule. Each project has some resources defined. When i do a report generation for the resource allocation for the master schedule, the report i get has the resources detailed for each project in the master schedule.
project 1
Resource 1
Resource 2
project 2
Resource 1
Resource 2
and so on.
How can i customize the report to get the sum of each resource for all the projects.
Resource 1
Resource 2
etc
thanks in advance
Raj
SOURCE: Excell workbooks
You need to learn how to use the, "Paste Link," function. If you copy the spreadsheet and paste the information into a new tab in the same workbook, using the 'paste link' feature, the information on the linked pages will update automatically each time you update the page the links are based upon.
SOURCE: i need total forms,code and some analysis about this project
front-end : ASP
back-end:MS access
operating system:windows xp,or windows professional 2008
NOTE :-forms desiging in HTML connected with ASP
SOURCE: Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
SOURCE: You might not have permission to use this network resource.
To solve the problem you must add: "NWLink IPXSPXNetBIOS Compatible Transport
>Protocol" to the “Network Properties” list on each computer of the network.
>The error message is misleading in that it has nothing to do with permissions or
>servers or logging on as administrator.
>Note: To add "NWLink IPXSPXNetBIOS Compatible Transport Protocol" open your Network
>Connections as explained below:
>1 - Go to Control Panel, and select "Network Connections";
>2 – Right-click with your mouse your Network Connection and select “Properties";
>3 - On the "Connection Properties" screen, select the "Install" tab;
> 4 - On the "Select networking Component" screen select "Protocol" double-click
the
>Add..." Tab;
>5 - On the "Select Network Protocol" screen, select "NWLink IPXSPXNetBIOS Compatible
> Transport Protocol" and click the "OK" tab to install the protocol.
>The steps above have to be repeated on every computer present in the Network.
goodluck
