Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
It has a new battery now i can't reset the time it is a crane viceroy radio controlled fintan
Posted by fjemmett on
Arturs Kalnins
  • 2,338 Answers
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all LA CROSSE watch manuals. Rate me, please
Posted on Mar 30, 2010
J. hughes
    New Friend:
I learned nothing from this site
Posted on Jun 05, 2013
Anonymous
How do I reset the date?
Posted on Sep 01, 2010
Require instructions on how to reset my Crane & Viceroy radio controlled watch details as PH16251 & cvw0002
Hi, to reset, remove battery, short out the -ve battery spring terminal to the ATM movement, this is the part of the watch in the centre of the lower part of battery holder, it has a small access hole through some clear insulator material. You need to pull up the battery spring a bit to see this. use tweezers to short it out. This discharges the watch circuit and resets it.
hope that helps and thanks for using fixya!
Sep 05, 2011 | Watches
Crane & Villeroy watch (radio controlled) After fitting a new battery it shows the time 1 hour behind the correct time.
It sounds like your watch is on daylight saving time (DST) or it is set to the wrong time zone.
If you press the "Mode" button you will enter the settings menu and you should be able to change this by pressing one of the other buttons. Some experimenting will be needed.
Sep 18, 2010 | Watches
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
I have a Carne & Viceroy Radio Controlled Watch reset time
I went to How To Mend It Site and I fixed the watch in ten minutes and it was free I expected fast response from you because of the charge.
Dec 18, 2009 | Watches
Having fitted a new battery I need to re-set a Crane & Viceroy atomic watch but cannot find the re-set button.
The reset is typically not a button. If you look at the back lid with the watch open you might have instructions to reset or "AC" the watch. Usually this involves using tweezers or lever to contact the battery and circuit board to clear it. My suggestion for this procedure is to see a watch maker/technician since the circuit board is easily damaged.
Sep 15, 2009 | Watches
I have a Radio controlled watch manaufactured by Crane & Viceroy. I need to fit a new battery.I have bought a new battery and would like to have a go at fitting it as I have never done this before....
I haven't seen this watch but I suspect the thin metal peice is the battery retainer. If so look carefully to see if it clips over the module at provably several points. If so gently prise them up to release the retainer. Wipe off new battery and install the correct way up. Replace retainer ensure it is correctly clipped in at all points. Set about recalibration process. If it doesn't have clips perhaps it has screws. If so remove them etc. Pleae rate this solution.
Jul 26, 2009 | Watches
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; [email protected]
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
895 people viewed this question
Top La Crosse Watches Experts
Ekse
Thomas Perkins
Thomas Perkins
Overmod
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
