Zanussi ZWF1440 Front Load Washer Logo
Posted on Mar 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer got stuck half way before program is finished
The washer got stuck half way before program "D" and the filter underneeth is filled with water the whole filter. The filters are clean I have checked. The water get stinky. The water does not want to go out.
Anonymous
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Mar 30, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
15184
Points
149
Your drain pump isnt working or there is a blockage in the sump, drain hose or plumbing
1helpful
1helpful
The program cottons not finish can I reset the program
yes u can reset ... if again not finishing , check the filter out
Siemens Dishwasher flooded. Now it doesn't take in any water and does not finish program. Aquastop filter?
Typically all dishwashers have a maximum full switch that is located on the bottom of the inside of the washer, on some it looks like a round plastic cap about two to three inches round, if you grab it it will move up and down as much as a half inch, this is a float that when the water level is at the maximum will turn off the water inlet solenoid, I have had something small (in my case a small lid) get under this float holding it in the up position so it would not allow the washer to fill with water, after removing the lid the float went back to the correct position and everything worked fine. I would say this is happening to you by what you say has happened.
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
1helpful
I set the machine to wash,it began to fill and several hours layer had filled to only 1/2 capacity with the timer showing the time remaining until the total wash time was finished. I turned it off and on...
It is possible that the inlet valve is clogged and so the water flow is restricted. You must obtain a good flow into the washer tank after the program is started.
So remove the inlet valve and clean the filter, clean the valve and set to test once again,
Since the program is delayed the program timer detects this as an error.
My zanussi washer dryer has some problem When i set a program and lets say the program is 125 min it finishes after 40 min and it is not spining.Also when I try different programs I have the same problem
check the drain filter is not blocked if it does not empty all the water it saves time on the next fill. also the spin will not happen if it has not emptied completley. a faulty pump would give the same effect.
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
