Heating & Cooling Logo
Posted on Mar 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove fan motor - Heating & Cooling
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 108 Answers
  • Posted on Mar 30, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
108
Questions
0
Helped
38915
Points
355
Fan
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its housing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season. Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure. However, if the condenser coil must be moved to get the fan out, do not try to remove the motor. Call a professional service person.
2answers
How do I replace my Nutone 669FN fan that is too noisy without having access anymore to the attic?
cover should pull down and removed. fan is installed with screws or nuts, replacement motors are available on line.
Apr 07, 2023 • Dryers
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
How to remove fan from rsl3c ?
Remove the bottom plate screws & bottom plate. Remove the screws holding the motor and fan assembly to the nozzle housing. Remove the screws Holding the fan housing to the motor to gain access to the fan. Remove the bolt holding the fan on the motor shaft to remove the fan.
Want to change fan on blower heater
Removal
  1. Remove wiper arms.
  2. Remove cowl panel.
  3. Disconnect blower motor electrical connector and vent tube.
  4. Remove blower motor retaining screws.
  1. Remove fan retaining nut from blower shaft through plenum opening while holding the fan from the engine compartment.
  2. Remove fan from blower motor while removing blower motor from vehicle.
Installation
  1. Hold fan through plenum opening.
  2. Install blower motor to vehicle while installing fan to blower motor.
  3. Install fan retaining nut to blower motor shaft through plenum opening.
  4. Install blower motor retaining screws.
  5. Connect electrical connector and vent tube.
  6. Install cowl panel.
  7. Install wiper arms.
1helpful
2answers
Need to replace radiator fan and its motor
need to remove the fan unscrew the fan center nut and remove fan blade from motor.to remove fan motor from shroud remove the three mounting screws in back of fan motor.
Light comes on but fan does not. Electrician just here and it is fan not switch
mcdevito75 here, If the fan is brand new and just installed, you may have forgotton to remove the brakes off the fan motor while installing the fan blades to the fan motor, these brakes are pieces of plastic to keep the fan motor from turning in the box while shipping from the factory, remove 1 fan blade and either on top or just underneath the fan motor where the blades screw on are small pieces of p[lastic that will keep the fan motor from working, simply remove these plastic brakes.
2helpful
Need location on blower motor resistor on 1994 pontiac bonneville
Fig. 1: The blower motor and fan assembly is mounted in the heater and A/C module, and is accessible from the engine compartment
GM Bonneville/Eighty Eight/LeSabre 1986-1999
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
  1. Disconnect the negative battery cable.
  2. If necessary, tag and disconnect the number 2, 4 and 6 spark plug wires from the ignition coil and move the coil out of the way.
  3. For 1993-99 vehicles, remove the nuts and cross brace bar.
  4. Detach the electrical connections from the blower motor.
  5. Disconnect the cooling tube from the blower motor.
  6. Unfasten the screws securing the blower motor to the blower module assembly.
  7. Remove the blower motor and fan assembly from the module.
  8. If necessary, unfasten the nut attaching the fan to the blower motor shaft, then pull the fan from the blower motor.
Fig. 2: You can disassemble the fan from the motor by removing the retaining nut
To install:
  1. If the fan was removed from the motor, position the fan on the shaft, then install the retaining nut. Tighten the nut to 12 inch lbs. (1.4 Nm).
  2. Position the blower motor and fan assembly to the module, then install the retaining screws. Tighten to 5 inch lbs. (0.6 Nm).
  3. Connect the cooling tube to the blower motor.
  4. Attach the electrical connector to the blower motor.
  5. On 1993-98 vehicles, install the cross brace bar and retaining nuts. Tighten the nuts to 18 ft. lbs. (25 Nm).
  6. If removed, install the coil and connect the spark plug wires, as tagged during removal.
  7. Connect the negative battery cable.
Hope this helped (remember rated and comment this).
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Need to replace the left rad fan motor, any ideas on how to do it if i have the new part?
    1. Remove radiator from vehicle.
    2. Remove fan shroud retaining bolts, and cooling fan motor/blade/shroud assembly.
    3. Remove fan blade retaining clips and blades.
    4. Remove motor mounting screws and motors.
    5. If necessary, remove Constant Control Relay Module (CCRM).
    6. Reverse procedure to install. Torque CCRM screws to 40-56 in lb, and shroud retaining bolts to 24-48 ft lb.
    1helpful
    2answers
    Haeir HRF10 refrigerator
    Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
    Top Heating & Cooling Experts
    Paul Carew
    john h
