How to install drive shaft on a husqvarna 322l weed eater 1999 model
The curved shaft machine has a flexible drive shaft like a speedo cable, slacken the two tube pinch bolts, these are accessed on the r/h side of the grey plastic handle through holes in the plastic housing,, remove the two mushroom headed screws either side of the plastic handle,don't lose the black o rings under the screw heads, do not remove any of the plastic housing screws, now carefully draw the tube out through the plastic handle/trigger assembly, once out pull out the old drive shaft, grease the new drive shaft and push back into the tube, once fully in turn the end to make sure the trimmer head turns, now feed the tube back through the trigger housing, make sure it is fully back home and the square end of the new shaft has entered the square hole in the drive drum, re tighten the pinch bolts, start the engine, if the head does not turn, slacken the pinch bolts and push the tube further in, re fit the two mushroom headed screws.
