Every time I turn on my computer it automatically comes up with the date 16/4/2016 and time 9.30am, not the current date and time. I have to change this every time I want to access the internet etc. How can I fix this problem. I am using Windows XP, and I am getting sick of having to do this every day.
Your cmos battery may be going bad. If you pull the side cover off of the desktop it should look like a big watch battery. Usually when the battery starts to go dead the pc clock is the first thing to go.
Setting the date and time in Windows 10 Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen. Click Adjust date/time. Make sure your Time zone is set properly if your computer is displaying the wrong time. To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8 In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time. Select Change date and time settings... in the bottom of the window that appears (shown below). Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button. Make your adjustments and click OK. Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
<p>The CMOS battery is named after the Complementary Metal
Oxide Semiconductor power. The CMOS has the current date and time functions for
desktop and laptop computers. It allows the computer to automatically adjust
the time, even on computers that are disconnected for long time. When a
computer no longer has the date and time and forget it on every boot, the CMOS
battery probably needs replacing. Some computers have messages when the battery
is weak, while others just lose the current date and time after each shutdown.<br />
<p>Time & Date Errors<span> </span><br />
<p><span> </span><br />
<p>1. Turn on the computer. Look in the task bar at the bottom
right. Make sure the date and time is set correctly. Double-click the time and
click the up or down arrow to switch to the correct time. Click on the arrow
next to month to change the month. Click "OK" when finished.<br />
<p><br />
<p>2. Turn off the computer. Wait 3 to 5 minutes and start the
machine.<br />
<p><br />
<p>3. Look on the taskbar to see if time was lost and said a
strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br />
<p><br />
<p>CMOS Error Message<br />
<p>1. Look for error messages like "CMOS checksum
error", "CMOS Read Error" or "CMOS battery failure"
when you start your computer. These errors are caused in the machines shut down
for several months or when the CMOS must be replaced.<br />
<p><br />
<p>2. Let the computer on for 24 hours. Restart the computer
and find the error.<br />
<p><br />
<p>3. Change the CMOS as the return error.<br />
Want to set the date and time for your mobile phone? Follow these easy instructions. From a Home screen, tap the Arrow icon to display all apps.
Navigate: Settings > Date & time.
To use network-provided values, turn on the following:
Automatic date & time
Automatic time zone
When manually setting data & time, perform the following:
Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
Tap Set date.
Adjust the date then tap OK.
Tap Set time.
Adjust the time then tap OK.
Tap Select time zone then select a time zone.
If desired, tap Use 24-hour format to turn on or off .
Make sure your iPad, iPhone or iPod touch has an Internet connection. You can check this by trying to visit a website (eg. Apple.com) in a web browser (eg. Safari). If the page does not load, or loads slowly, try to turn on and turn off the unit's Wi-Fi connection. If you still can not connect, there may be problems with the Internet connection.
Check the date and time of your Apple iPad, iPhone or iPod touch
If the date and time on your device is very different from the current date and the current time, it will cause problems with videoafspilning.1.Tryk icon (Settings) on the home screen. 2. Press General (General). 3. Press the Date and Time (Date & Time). 4. Press the Set Date and Time (Set Date & Time) .?Hvis date and time is not correct, adjust this until it fits with your time zone. ?Eller switch On / Off (On / Off) On (On) in the Set automatically (Set Automatically).
Install Netflix app again
1.On the main menu, press the Netflix app and hold your finger on it until the icon vibrates. 2. Press the X in the upper left corner of the Netflix icon, and then press Delete (Delete). 3. Go to the App Store, search for "Netflix" and choose the free Netflix app from Netflix, Inc. 4. Press the Install button (Install). You must enter your password to iTunes to install the app. 5. When the app is installed, tap the Netflix icon. 6.Indtast e-mail address and password for your Netflix account, and then tap Sign in (Sign In).
1 Press Menu or and select Settings. 2 Select Date & Time and choose from the list below: Set date - You can enter the current date. Date format - You can set the date format. (YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY) Set time - You can enter the current time. Time format - You can set the time format to either 24 hours or 12 hours. Auto update - Select OFF, the phone will NOT automatically update the date and time.
Select Menu > Settings > Date and time.
To set the date and time, select Date & time settings.
To set the formats for date and time, select Date & time
format.
To set the phone to update the time and date automatically
according to the current timezone.
You can get more help from downloading the manual from Nokia at http://nds1.nokia.com/phones/files/guides/Nokia_7020_UG_en.pdf
First, you need to have administrative rights to change date and time.
Check whether you are part of admin group or not. To check click on start and click on run, type "control userpasswords2" and hit enter. It will display user information, make sure you are part of administrators group. If not, try logging from administrator and run the same command
"control userpasswords2" and click on your user name and click on properties, go to to group membership tab and select others and then select administrators. This will make you part of administrators group. If this doesnt solves you problem try the CMOS Settings.
Try changing the date & time from CMOS settings. To go to CMOS Setup, restart the system and there will be options highlited to go to setup.. ( eg press F10 Steup ) and play around only date and time setup. Rest if not known to you, do not change anything.
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
Select Menu > Settings > Date and time. Select Date and
time settings to set the date and time. Select Date and
time format settings to set the formats for date and time.
Select Auto-update of date & time (network service) to set
according to the current time zone.
Hope it helped...
