Question about Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the cycle by numberous attemps in pressing pause/cancel,drain & spin and a few other combinations. Is there anything you could suggest.
    New Friend:
  • 77 Answers
Wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Posted on Mar 30, 2010
  • sandygammie Apr 27, 2011
    Mine is doing the same thing? I replaced the door lock thinking that would solve the problem.... it did not. It does some clicking noises and sometimes the door locks but get the error code fdl. I have unpluged the stupid thing, wiggled all the wires, re plugged them all back in and tried to start the machine and just get the beeping and the error code. Another $100. down the drain. Now I am thinking its the main control board. I have no idea how much that will cost or is there something else I can try to get my machine working again???
Anonymous
SOURCE:
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Door won't latch and dL and F come up
your dl (door latch) is broken replace it you can order it from searsparts.com
Apr 26, 2009 | Kenmore Washing Machines
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
309 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
