Question about Dell OptiPlex GX110 PC Desktop
Dell GX110 not booting from CD Problem - Dell OptiPlex GX110 PC Desktop
Posted by lookinsudbur on
woozie38
  • 608 Answers
You may need to set your CMOS boot priority to 'boot from CD drive". Put your boot disk in the drive and start the computer. Press 'delete' while booting up and you'll enter CMOS setup . Locate boot priority and set this to #1 boot from CD. Save and exit. Your computer will now seek and boot from the dive you set to.
Posted on Mar 29, 2010
electronic & computer repair& servicre
  • Dell Master
  • 12,061 Answers
Have you set BIOS to Boot from the CD/DVD? If not please do that.
1 Related Answer
richroth
Richard Roth
  • 9472 Answers
SOURCE: Dell optiplex gx110 will not start
The power supply fan is running or the CPU fan?
Posted on Nov 02, 2012
How to reset password on Dell OptiPlex GX110,and get it to disable
Best way to achieve this is boot the computer using Hirens boot cd.
See my link for site and explanation.
I have used this method myself on several occasions.
Maybe not for absolute beginners.
Good luck trying.
A.Misset
Nov 24, 2016 | Dell Computers & Internet
Cd rom detection problem on optiplex gx110
have you checked to see if the cd drive is showing up in MY COMPUTER?
if it's not the it's possible that the cd drive needs to be replaced
Apr 04, 2012 | Dell OptiPlex GX110 PC Desktop
My dell optiplex gx110 wont boot, it stops at the xp logo, i am running windows xp
Windows gone corrupt, might be infected by virus, need to re-install, from recovery CD or by windows xp CD.
Good luck, do rate the solution if got help
Dec 02, 2010 | Dell Optiplex GX110 (2909T) Motherboard
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
I cannot locate the ide cd rom drive in the bios setup of a dell gx110 what should i do
restart and boot in bios and press F9 then F10, shot down and check for jumper it must be slave when connected parallel with hdd master. start again and check bios if dvd drive detected.
Mar 26, 2010 | Dell OPTIPLEX GX 110/200 PIII-733MHz 256MB...
Dell Optiplex GX110 will not come on when I press button but i hear clicking sound is there any way I can fix this problem?
A gx110 is pretty much uneconomically repairable. If the system is powering on, getting video but not booting, then the clicking is likely the hard drive. Of you are not getting any video, then post what the Power LED and the diag LEDs on the back of the tower indicate.
Oct 04, 2009 | Dell OptiPlex GX110 PC Desktop
My dell optiplex GX110 motherboard problem
I would suggest defaulting the bios, either by way of the cmos jumper, or by entering the bios at boot, selecting "load defaults" from the menu at the bottom of the screen, save and exit. If setting the defaults does not fix the onboard IDE then you have a hardware failure. They make IDE adaptors that plug into a PCI slot, that could get you back into operation, but I'm afraid if the IDE has gone on the mobo, what's next? I would be afraid something else will fail.
Maybe you'll get lucky with the defaults.
Jul 14, 2009 | Dell Optiplex GX110 (2909T) Motherboard
Dell OptiPlex GX110 PC Desktop Logo
467 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
