Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer won't start - Canon PIXMA iP3000 InkJet Photo Printer
Posted by hapereyda on
JM Alvis
  • 164 Answers
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Posted on Mar 31, 2010
My s301 won't scan. Won't download application list.
Try scanning from Lexmark Printer Home. To do that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Jan 02, 2013 | Lexmark Impact S301 Wireless All-in-one...
Scanner won't work
Try scanning using our Lexmark Printer Home. To do that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Oct 17, 2012 | Lexmark Prospect Pro205 Wireless...
Canon Pixma 560 won't turn on
make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope this helps
Jul 28, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | Computers & Internet
Overflow ink reservoir in canon i950 printer is full so it won't print
Dear jhurst, see a small door at the back of the printer. (in some printer it is in bellow) which is screwed. Unscrew it. There is a small pipe, which always filled with waste ink. clean it. start the printer, it will work.
Sep 01, 2011 | Canon i950 InkJet Photo Printer
HP Photosmart C5580 All-In-One Inkjet Printer all lights started flashing and it won't work.
Solution 1: Open the lid and watch the cartridges go back and forth. It might happen, that after couple of hours of just sitting down the printer starts doing the same again.
Solution 2: Lights flashing sas turn power off, then on again, so try this then
Jul 06, 2011 | Office Equipment & Supplies
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
195 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
