Question about Casio Watches
Need a user's guide for a recently purchased Casio watch [2515] D8-360, 4 button, silver, square face, illuminator, with reverse and forward buttons. Thank you.
Posted by tedpolgar on
Arturs Kalnins
  • 2,338 Answers
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIOwatch manuals.Rate me, please..
Posted on Mar 29, 2010
How do i change time on casio illuminator?
dear please
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode. Press "C" to return to timekeeping mode.
Sep 13, 2011 | Casio Watches
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
Need to set time on casio illuminator AW-81
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 29, 2011 | Casio Illuminator watch #AW82D7AV Watch...
How do I change 24 hour time to 12 hour
You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
Jan 27, 2011 | Casio G-Shock Classic DW6900-1V Wrist...
Change annalog time Casio illuminator
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Dec 22, 2009 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
Turn off alarm
go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
Aug 24, 2009 | Casio DB36-1AV Wrist Watch
Lost manual TGHK
I was trying to find a solution to this problem on line, and then I stumbled on it myself while playing around with it. Here it goes:
Your 4 buttons on you watch are:
Light Start
Mode Reset
While looking at the time, hold in the Light and Reset buttons at the same time with 2 fingers from your left hand. This will put the alarm time in the display. While still holding those 2 buttons down, use you right hand to press the Start button. This will cause the alarm signal to go away (or go on if it off when you do it). Problem Solved !!!!!!!!!!!!!!!!!!!!!
Dec 17, 2008 | Watches
Setting Time
Hold in the adjust button until the seconds start to flash. Then push the mode button until the hour is flashing. When the hour is flashing push the forward button to advance it one hour. After you do this hit the adjust button to exit the set mode.
Mar 09, 2008 | Watches
Watches Logo
100 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Robert
Are you a Casio Watch Expert? Answer questions, earn points and help others
