Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Have picture in black & white no color. audio
Have picture in black & white no color. audio not working.
have turned tv off and on.
have tried to adjust audio and picture control no help
have reset to factory specs. menu 1-2-3 no effect...
  • Anonymous Mar 29, 2010
    does this cover the No audio also. have been told it could be in the tuner section....
    It has color and audio when hooked up to a DVD player.
Antonio Cruz
  • 336 Answers
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Posted on Mar 29, 2010
My tv has too much red in picture
Adjust the color control down, first turn color off see if you have a Black and white Picture if not you need to adjust screen drive controls to each tube untill you have Blk and WHT picture then turn color back on.
Mar 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
My color seems to be more green than should be and I have tried to reset the color with no help
You have a focus/screen control box Find it and adjust the R/G/B screen drives When you first start Go to Menu turn Color off then with a mirror adjust the picture as close as you can to a black and white picture R/G/B screen drives, the little control box you are looking for will have 3 controls on top for focus and 3 controls under them for screen drives to each tube red,green,blue after you have adjusted to a black and white picture then go back and turn color on.
Nov 30, 2009 | Akai PT4298HD Rear Projection Television
Picture is now black and white
 First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable
 transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
  1. Weak signal or defect in tuner/IF causing loss of signal strength.
  2. Coler killer set too high (internal control) if it has one.
  3. Defective part around the chroma chip/circuit. Faulty color oscillator.
  4. Bad connections in area of chroma chip/circuit.
  5. Defective chroma chip (don't suspect this first just because it is probably very expensive).
A service manual or Sams', DMM, and scope will help greatly in attempting to troubleshoot this unless it is an obvious bad connection. Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
May 08, 2009 | JVC AV-36S33 36" TV
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
524 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
