If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
though it's still the same cable.... I have a phono input on my usb card, which you don't see often and it works perfect, but if you're gonna digitize to a better format then mp3, which is everything and use audicity, use as Few options as possible, remove some groundnoise is often enough or you have a bad needle, then will it never be good.
