Canon SmartBase MP360 All-In-One InkJet Printer Logo
Anonymous Posted on Mar 29, 2010
Canon mp360 prints 1 page document on multiple pages.
When I try to print it prints say the first five lines of the text and then starts to print on another piece of paper, printinting 1 or 2 more lines of text and then starts on another piece and so on.So I end up with a 1 page document printing on about 15 seperate pieces of paper.
Have reinstalled drivers and the settings are for A4 paper and everything is default, but no change.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 12, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470250
Points
19564
CANON IP 4300 PRINTERS WILL ONLY PRINT ALTERNATE LINES
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
tip
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
PRINTING PROBLEM
most probably the setting in your document. try to see header and footer settings
WHen printing from MS Word academic version, the canon MX310 will print 1 page across multiple pieces of paper, at random. The drivers have been reinstalled. Any ideas?
Many programs allow you to change the size of the page for the document you are creating. If the size of the page defined in the program is different than the size of the page set in the printer driver, the document may print too small or over multiple pages.
In the application you wish to print from, check for a 'Page Setup' option in the 'File' menu. Make sure that the defined page size in 'Page Setup' matches the printer's settings. If you are unable to locate 'Page Setup', consult the application's 'Help' files or manual.
3helpful
Canon SnartBase MP360 goes through motions of
try to unplugg it install drivers then plugg and reboot and try a teset page.
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
2helpful
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
4helpful
2answers
Canon Mp 210 Scanner printer
go into administrative tools click on services and make sure windows image acquisition (WIA) is on manual
old marine
old marine
ZJ Limited
ZJ Limited
