Question about Olympus EVOLT E-500 Digital Camera
Olympus zukio 14-45mm lens does not auto focus or zoom not sure if it hit anything after the last shoot
Posted by demetrius467 on
Anonymous
    Master:
  • 411 Answers
Does not do focus/zoom properly,is due to defective mechanism of the lens unit,so get it serviced.
Posted on Mar 29, 2010
Why wont my Olympus zuiko 300mm lens zoom to max length?
Most camera's can't focus when the aperture number is above 5,6. Although your tele zoom starts at 4,8, it reaches the 5,6 at about 150 mm. So from there and up it can't auto focus. You still should be able to focus manually, but for wild life or sports pictures, it is useless.
Aug 25, 2014 | Olympus M 75-300mm F/4.8-6.7 ED Zuiko...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
How to use a manual zoom lens with Evolt 510
By manual zoom lens I am assuming you mean a film camera lens. If it is one of our OM 1 or 2 lenses they can be used on our Olympus digital SLR camera but you will need to purchase an MF-OM1 converter to be able to adapt those lenses to fit on our digital SLR camera. Then you will only be able to shoot using those lens in manual focus mode. Auto focus mode will not be available.
Sep 25, 2008 | Olympus Cameras
My Olympus 740 digital camera does not auto focus any more. I can make it focus for the most part by zooming in, but is there anything I can do to make it start up focused? I had another Olympus camera...
Take it off manual focus? There may be an "all reset" option in one of the menus that makes the camera factory default whenever its turned on, usually this is full auto mode. If the camera will only focus when the zoom is used, there may be a secondary lens inside the lens barrel that is not moving as it should. Time to service it if that is the case.
Jul 07, 2008 | Olympus Cameras
Olympus E-510 70-300zukio
The markings on the lens barrel are for macro mode purposes. When the zoom ring is set for 300mm that is the distance you are shooting at. It will zoom the barrel all the way out to 300mm if it needs to to help to obtain focus on the subject.
Hope this clears things up for you.
Feb 19, 2008 | Olympus EVOLT E-500 Digital Camera
Auto focus not working properly
I have the same problem with my camera. What did you do about your autofocus mess?
Oct 27, 2007 | Olympus Camedia C-2040 Zoom Digital Camera
Help!! 10-year old Accura Zoom 80 film camera is taking blurry photos all of a sudden
you should be able to place your hand in front of the auto focus window while looking in front of camera (be careful not to blind yourself with the flash) you should notice the lens moving sightly as if to focus. The best way though is to actually shoot a roll through it. Do not shoot a wedding or anything of real importance...the cost of a roll of film and develop is worth piece of mind.
Jul 04, 2007 | Olympus Accura Zoom 80 35mm Point and...
Focussing
Two possible solutions. The camera may be set to Macro. The lens may have failed. If the camera is not set to macro then the lens has to be replaced and the camera reprogrammed.
Sep 11, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus camedia c-300 zoom auto focus
hi, really surprising, how could you fix the problem, it will be fixed only by replacing the lens assy. so just go to olympus shop. good luck....
Jul 28, 2006 | Olympus Camedia C-300 Zoom Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
