Canon CanoScan  LiDE 70 Flatbed Scanner Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canoscan lide 70 "unable to select twain I uninstalled everything.. this all happened after I tried to install an old canon camera. The scanner is identified.. it makes it's normal sounds during boot... I can't even use the scanner through photoshop.. I have windows 7.. it worked fine before the camera install . Everything is up to date..
Anonymous
Level 3:
Guru:
  • Canon Master 1,705 Answers
  • Posted on Mar 29, 2010
Anonymous
Canon Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402373
Points
5112
Looks like things have got a bit mixed up with the canon software. Try this:-
1) Un-install the camera.
2) Un-install the scanner.
3) Re-start the PC.
4) Re-install the scanner.
Unable open twain source please
This is an issue with the Driver Installation, Get the drivers Uninstall and reinstalled from the CD.
2answers
Canoscan Lide 60 suddenly cannot be communicated.
hi um i don't know if this will actually work but it did for me, I had 2 problems with the lide 60 scanner-one was a connection/cable thing and another was this "TWAIN source thing" and after installing this:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
i seem to only have one....i think the connection/cable got fixed.
oh well, give it a try anyway :) cant hurt
Twain Complient
twain data transfetr error help please
1helpful
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
2helpful
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
2answers
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
Cannot TWAIN CanoScan LiDE 500F
What errors do you recieve? Where are you scanning from...what application?
3answers
Twain error
Buy a new scanner that doesn't say 'Canon' on it anywhere. Mine's useless too, for the same reason. Canon don't want to know about it. Berty
old marine
old marine
ZJ Limited
ZJ Limited
