Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
How to reset a k9 remote
Hello I have three old remote system with my suv, model k-9 remote FFC ID : L2MAL41T. One works but the other two do not and in past they did. I left the battery in them die out. I replaced the batteries but now they do not open the car. How do I reprogram all these remotes to work with the car?
Posted by apicamilho on
1 Related Answer
Anonymous
  • 41 Answers
SOURCE: trying to program a new remote to my car alarm
turn key to on position push valet 5 times then hit lock on the remote
Posted on Feb 03, 2010
Fcc id l2mal41t
you need to locate the alarm box under plastic's drivers side kick panel or behind glove box and search unit details or get back to me and i will hunt.
Apr 05, 2014 | Vehicle Parts & Accessories
Tip
DISASSEMBLING SERVICE MODE AND POWER SUPPLY CIRCUIT
DISASSEMBLING
(Follow the procedure below in reverse order when reassembling.)
1. Top Panel Unit
(1) Remove 9 side screws and pull up the Top Panel Unit.
(2) Disconnect FFC cable and Connector.
(3) Detach Top Panel Unit
Note : Do not pull out aslant to prevent FFC cable damage.
Do not fail to pull AC cord from wall outlet before disconnect the FFC cable.
If AC cord is remained plugged into wall outlet,
power is kept supplied in the unit, which may cause
danger.
For more check the following link
http://electro-medical.blogspot.in/
on Feb 24, 2015 | Denon Dn-X1500 Professional DJ Mixer...
On/off button not working
k9 on off problam..........plz help me
Jun 06, 2012 | Karbonn K9
My touchpad won't work. i disconnected the ribbon
Here is the main page for the Dell Inspiron Mini 910 (9) Notebook PC,
http://support.dell.com/support/edocs/systems/ins910/en/sm/index.htm
Click on - Palm Rest
Scroll down the page to the second photo.
The TouchPad cable is a FFC.
Flat Flex Cable
It slides into the Flat Flex Cable connector on the motherboard.
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The Flat Flex connector is rectangular in shape, and composed of two parts.
The lower larger part is attached to the motherboard, and does not move.
The smaller part on top is movable.
The smaller part locks the FFC in place.
There are two tabs on each top corner of the smaller part. These tabs are eased up to release the FFC.
The tip of the FFC has copper contacts. These contacts must align with the contacts, in the Flat Flex cable's connector on the motherboard.
Then the smaller part is locked back into place.
Noted the above in case you just pulled the FF C out of the FF C connector on the motherboard.
There is a stripe on one side of the FFC.
(Flat Flex Cable)
This stripe goes to the Left side of the laptop as you are viewing it from the front.
Regards,
joecoolvette
{If somehow this direction is wrong, flip the cable over}
Jun 21, 2011 | Dell Inspiron Mini 9 Laptop
Hello,i have samsung 13" tv
The original remote has an infrared sensor that you point to the tv "looks like a led except it see through" it has become defective and must be changed, some service shops may carry some, also try Radio Shack.
Feb 06, 2011 | Samsung TXJ1366 13" TV
Recode a key 4 bmw 318i cenral locking
To carry out this procedure you need to have one working key and one key which requires programming. It may help sometimes to hold the key close to the rear view mirror as this is where the sensor is located in most models. 1. With both keys, get in the car and close all windows and doors. 2. Put working key into the ignition and turn to position 1 (the accessories should turn on) (try also position 2) 3. Turn the key back to position 0 and take the key out of the ignition. 4. Using the working key, hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button. Doors should lock and unlock. 5. With the new key, hold down the unlock button and press the BMW logo (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!! If not working try the following PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation. If this doent work your alarm/central lock needs to be reset
Mar 28, 2009 | 1996 BMW 318
Black screen and three beeps
your m/boar is now not supporting the ddr which you are putting in, so you have to replace your ddr with Kingston DDR it'll solve the problem
Dec 06, 2008 | ASUS K8V-MX Motherboard
Bmw e36 1996 318is
If ews2 alarm is fitted it need to be reset by computer. Any tampering will set it into protectction mode. Had similar problem. You can try the following but if it does not work get someonr with diagnostic computer. PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation.
Jul 01, 2008 | 1996 BMW 318
Dish network
Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
Dec 11, 2007 | DISH Network IR Remote Control
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
945 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
